h22 help
  • h22 help
    iight so i finished my h22 swap i went to go turn it on for the first time and it started fine now i went to go start it today and itz makin a whining noise and its not even crankin over
    btw i changed the started and dat wasnt the problem
      did u do timeing on it be for putting it in? if not check ur starter it might not be engageing ..all da way.. my starter dose dat in winter,then i go to crank again and it starts...did u hit da starter while u crank it?
        the STARTER!!!!!!
        www.solavei.com/lopez2333
          fuck do i really got to show u some skills lol
            1. check your starter to see if its actually making contact
            2.check your timing belt
            3. if its making that whining noise and spinning fast then check if that little "key" and bolt are in the harmonic balancer because one time i dint tighten down that bolt all the way and the bolt fell out and then the little key fell out so my crank was just spinning away :)
