h22 help
  • h22 help
    CLOSE all ready got it fix
    i need help
    i got a h22 an is over heating
    the water is coming out of the plastic container super hot is freaking boiling and everything
    i took the thermostat out an it still doing it
    dose any one know what it could be
    they told me that the head in my engine cold be bend
    what do ya think
    water pump? radiator and/or fan not big enough? Thats what was wrong with mine and once i changed that I was good
    NHBP Dc5
    R.I.P Nick (nhswaps)
    Gone but Never forgotten
      the car has a new water pump and today i just put a dual core radiator an the fan is that small one that you buy that there better then the stock ones
        have u tried bleedin tha cooling system if u have try flushing tha coolant
        B SERIES INC....
          my brother told me about thet today bleed the cooling i was going to do that tomorrow
            did you put coolant in it or just water?
              i was doing water for now just to try my engine out an then i was going to get coolant
                thats prolly ur problem. drain it, put coolant, bleed the system n hopefully u didnt blow ur head gasket.
                  OK im going to try that out tomorrow
                    lol if the waters boiling and melting plastic the headgasket is the least of your worries. your heads probably warped now
                      is not melting the plastic is just coming out of the host mad hot
                        how long did it run before you realized it was overheating
                          na i just went around the block to text the engine out went i got to my house again the needle was on hot an i turn my car off mad fast
                            oo then you should be good.
                            drain the radiator completely put coolant in it. turn the car on leave the radiator cap off! as the car starts to warm up you will notice bubbles comming from the top of the radiator. the heat is making the air rise and pushing it out of the where the cap is suppose to be. keep filling the radiator until it wont take anymore and stops bubbling. that means there is no more air in your radiator. you should be good after that make sure you check for oil/coolant mix on the oil cap. if its mixing you probably blew your headgasket. but if you really turned it off that fas then it should be fine
                              thanks man im going to do that tomorrow to se
