ITB question??
  • ITB question??
    i got a h22 im planing on putting ITB on it
    but i want o know everything i need to put it in my car
    waste of gas lol .
      build your car.. put down as much power as you can get out of it.. then get itb's and tune it
        u need jb weld zip ties sum good sticky gum ummm superglue and sum fishing line
          dont forget the head light fluid.
            if ya don't no what i need don't write shit at all danm
              all u need is the itb's dont get butthurt
                its pointless to get itb's on a somewhat stock set up.. can you give us to what is/or will be done to the motor?
                  no rmeber if u dont have info please dont post. imo if u dont know what u need to put them on you shouldnt be getting them.
                    LMFAO, itbs on a h22 are worthless now on a type-r or or k-series thats worth but come on h22
                      How do you figure? Itb's aren't worthless on any motor unless the motor is stock. If you aren't building the engine then don't go with itb's just stick to a decent manifold setup.
                      But here ya go...
                      -Itb's
                      -Coolant
                      -Throttle Cable
                      -Intake
                      -Injectors
                      -Fuel Lines
                      -Vaccum Block
                      -Vaccum Lines
                      -Tune, Tune, Tune
                      It all depense on what kind of itb's you go with on which you need.
                        well its clear hes going with obx itbs since they are going on a stock motor. without high compression itbs are rather useless. turbohatch900 clearly doesnt know much dont pick on him. if you dont have ATLEAST STAGE 1 CAMS! and 11:5:1 or over compression DO NOT BOTHER its a waste of money and if you dont have the cash for twm dont bother. h22 built with itbs will skoot pretty good if you do everything right but from the sound of it you are peicing this together last minute. id also suggest a yosolo tune on this set up...
                        you wanted it, you got it
                          hahahaha funny guy! i know enough
                            well ill just agree with you and take your word. turbo hatch9000 is right. itbs suck unless you have a type r or k series
                            and h22 on itbs is slow...
                            first run for www.dhracing.biz crx on new motor granny shifting no good suspension needs workdhracing new stealth honda throtle bodies really worked good no...
                              you see i didnt mean it like that i was trying to say on a stock build they wont be good but on a nice build yes they would do a nice premium
