Yo... has anyone done this swap?? I have a 92 bubble and a 97 h22 motor and tranny.... i'm thinking it should be the same as a gsr swap but I wanted to make sure.
H22 in a 92-95 civic
so where is the big difference? I got to swap a JDM f20 motor for one of my boys into his 98 prelude....swap comes with everything which means I will have everything from the prelude... besides the mounts is there anything else I will need to change( I know that I will need adapters for the injectors cause there obdII) Let me know just a real rookie withthis swap and don't want to miss the simple shit13TH
DEV-ILL
Good look on the info.. yea I got a super deal on both the car and the motor so I might mess with a the H2b kit if it's reasonable. How much can you get the mounts axels and H2b kit for? Just curious and the H22 tranny is mint so I would probably want to sell that if I went this route.13TH
DEV-ILL
honestly, the gearing on the h22 tranny isn't bad at all, especially if you have a jdm tranny (their gears are a little bit closer than their usdm counterpart). those h2b adapter plates usually run upwards of $800, and from what i've heard (and i don't know if this is true), you have to still get a custom mount for it
either way you're going to spend a good amount of $$$ doing the swap with all the parts you have to buy. the little things add up :D
but if you put in the h, you won't be disappointed. the all-motor b-series guys won't stand a chance as long as you have a good tune
h22 eg help
whats up ctvtec me and my boy are doin a swap into a 93 coupe i just have a quick question im doin an h22 swap into a ej1 and we cant get the tranny mount to line up yea i kno u gotta cut some of the bracket and drill the holes for the bolt and what not but with the mounts i got (innovative) comes with their own bracket so we take off the stock bracket and drop the motor in the cAR we bolt up the accord rear bracket and also the driverside mount then when we go to put on the tranny bracket and mount but it doesnt line up the motor was about a half inch to the right of the mount do u have any idea why this would happen??Fuk the Honda game..you Put in Money Sweat and Tears for it to disappear.FUK BROKE NIKKAZ
