H22 No Compression!!Please Help?
  • H22 No Compression!!Please Help?
    So this past weekend I spent it working on my h swapped delsol. Its a jdm H22.Pretty much I replace the head with a another head w/skunk2 internals,timing belt,Head gasket etc.So I put it all back together and put it back on timing. I went to start it an it turned over like if it had no compression.I went ahead an did a compression test..To my surprise it measure 0 all across.At the moment I really dont know what it could be..The head is torqued to specs the head gasket is on correctly I can see the tabs.I rechecked the timing and everything looks good..Please help!! ???
    good luck some 1 help him out
      Something is deffenitely wrong internally
      *S14 Kouki *
        Well I did some research.. I think a it comes down to a valve adjustment... Ima give it a shot today
          Thats what I would start with.
            well....YA!
            I DO REMOTE STARTS!
              Originally posted by NHSwaps13203 View Post
              well....YA!
              Do any of you guys how to do a valve adjustment?? I don't care I'll pay as long as it's done right... How much??
                well....YA!
                  were you located ??
                  !!!!!ThE GoOd DiE YoUnG!!!!!
                    definity start with valve adjustment then go from there.
                      Alright Bro, I'm not gonna make it tonight, but I will be able to tomorrow, like we discussed. I'll hit you tomorrow afternoon & we'll make this happen.
                        Originally posted by jrsc_b18c1_12psi View Post
                        were you located ??
                        im located in new haven
                          aight kool bro thanx
                            any updates bro??
                              Yeah it came down to a simple valve adjustment cuz I upgraded cams... Honestly I forgot all about it... Its all done know jus gettin the rest of the parts together to go back for a tune..
