h22 95 integra axle issue...please help!!!!!!!!
  • #16
    We have done the swap u have to use
    -90-93 acord 1/2 shaft
    -90-93 da axels
    --if u use the lude 1/2 shaft u use
    --pass side da axle
    --the drivers is a put to gether w the
    --iner hub from a lude
    --outer hub from a dc
    --the center from a 88-89 integra
    or by gater axels and the will give u the right ones for your mount kit
    ..DRV-MOTR-WRX
    .STOCK SWAPS R NOT FAST
    • #17
      if i could do it u could do it
      U sould of saved som money like 3500 and did a H2b setup
      • #18
        try honda-tech.com
        • #19
          finally solved thanks to gator racing axles in fl...thanks peoples for your help
