wats up ctvtec. i want to put an h22 in my accord but doing alittle research i came to hear that a type sh doesnt fit. just wondering if anyone can help me out or let me know why or how?
h22 in 97 accord
Originally posted by blk_cd7 View Postso does that mean i can put it in my car
why exactly do you want to put a h22 in an accord the stock f22 can accelerate a decent speed it would but more cost effective to bolt in a turbo since the f22's compression ratio is low enough... if you run an h22 you will not have enough room to turbo and will be stuck running a NA engine unless you seriously modify the engine compartment... I run a 95 honda accord f22 with t3/t4 turbo and a mishimoto performance radiator to cool the whole thing
Originally posted by f22accord View Postwhy exactly do you want to put a h22 in an accord the stock f22 can accelerate a decent speed it would but more cost effective to bolt in a turbo since the f22's compression ratio is low enough... if you run an h22 you will not have enough room to turbo and will be stuck running a NA engine unless you seriously modify the engine compartment... I run a 95 honda accord f22 with t3/t4 turbo and a mishimoto performance radiator to cool the whole thingR.I.P Nick aka NHSwaps
In my opinion, if you're gonna do a swap on the Accord, go with the F20B (200hp/144ftlbs), you'll make more power. A guy on my other site is putting down about 175 WHP with I/H/E and a mildly ported IM. Only thing with the F20B is it falls a little short on torque. But the way I see it, we drive Accords, we're used to having no torque. :D
Dyno: http://www.6thgenaccord.com/forums/s...highlight=f20b
A Mild N/A H22, H23-VTEC build will be as fast or most likely faster than a boosted F22, F23.13203
