stupid question.
  • #16
    Originally posted by sit22 II View Post
    do the aaa thing mke them leave the car in a spot then wait some time and call them again
    lmfao! thats a good idea!!!!! hahah
    • #17
      Originally posted by 203AllMotor View Post
      go to uhual and rent a 2 wheel tow dolley its $30 for a whole day. and just find a friend with a tow hook and u can tow it yaself. and ive done that plenty of times from nj to ct without the car beig registered and never had a problem so just give uhual a fake licence plate number for the car your towing
      that sounds like the safest / easiest answer 4 ya
      • #18
        gotta be 18 or have a credit card around here to rent one.
        • #19
          socks being under age lol
          • #20
            yeah you gotta be 18 but you dont need a credit card you just gotta leave a deposit of $60. and im pretty sure you have cousins,brother/siter, friends or parents that are over 18 that will look out
            • #21
              stock b16 head and a stock ls bottomend.
              i wanna try it but if something else f#cked up id be out of a car until i got a different motor.
              It still depends on how much material was cut from the Head surface, & Block deck.
              If you know which valve it is, you can lift the valve cover & un-screw the valve tappet to maximum clearance, that way the valve will barely open, which will prevent valve-to-piston contact. Motor will only run on like 3 1/2 cylinders, but shoud get you home.
              • #22
                that's a damn good idea too, leaving the valve clearance on the rocker as loose as possible. if i were in a pinch and HAD to drive it home, this is probably what I'd do.
                590852836f5fbce940_b
                • #23
                  I got stock b16 valves an springs + tetainers..holla cheap
                  WILSON BUILT
