Help!! Water pipe to thermostat housing
  • Help!! Water pipe to thermostat housing
    Any advice on how to connect this thing?
    The water pipe that goes to the thermostat housing?
    On a 95 gsr
    I jammed it in as much as I can, but there's still alittle bit of the lip sticking out and it's leaking
    Please!!! Any help
    Thanks
    make sure the o ring isnt too big or too small
    Turn Tragedy into Triumph
      Try put some lube on so it slips all the way on nd ur good if u have new o rings simple as that the lub is to ensure a slip fit not jamming it on
