Brakes wearing?!?!
  • Brakes wearing?!?!
    Wats up guys the front pads on my 94 integra are wearing way too fast.
    Only on the left side
    I changed the rotors thinking it would fix it
    2000 miles later they are worn again, and I think only one pad, like the left pad.
    Any ideas wats causing this?!
    Lmk please thanks guys
    Remove the caliper and see if the piston compresses easily. It could be sticking. I would also check the slides and make sure they are rust free and everything is lubed properly. Sometimes rust forms underneath the metal slides and causes the pads to get stuck.
      All that is fine, when I changed the pads piston went down fine, also lubed slider properly, I thinking I should replace the caliper
        Try bleeding the system to see if theres any restrictions in the line that connects to the caliper
          Yea I guess I'm Gona try that if not I'm guessing the next step is to replace the whole caliper. Thanks for the help
            Bleed your brakes.
