so i go to take the nuts off to switch intake manis and the bottom center nut is stripped... how the hell do i remove this? help asap
stripped nut on d15b intake mani
Originally posted by SeanJDMJohn View PostI would help but u prob don't want me to also is it in the car? If not get a dremel nd grind 2 sides flat the use vise grips I have new studs everything if u need
Originally posted by high on ej6 View PostTap it with a hammer few times than try again...I just used visegrips on my b16 heads to change the studs for longer ones to use a thermogasket nd they all came out just fine
but man ill give u a couple free and ik how it is u would have to attack it from under the car like I said use a dremel tool to grind 2 perpendicular flat spots on the nut and use vise grips to loosen it u might have to take off the oil filter for more roomOriginally posted by Deathwish203Im on welfare...can i get a better deal???where u located
Originally posted by SeanJDMJohn View PostHis problems isn't the studs..yet..his issue is the nut is stripped
