Help! Radio not working
  • Help! Radio not working
    So my radio stopped working out of no where in my integra, I disconnected, re connected all the wires to the harness, fuses as good, and still won't work, any suggestions in what else it could be? Any info helps, thanks
      there should be a secondary fuse under your hood in the fuse panel labelled "back up"
      this might not be causing the problem... but not many people know that this fuse is a secondary fuse for your radio, clock etc.
        I tried that one, it was good, it was labeled back (radio), under dash and back of radio fuses are good too
          Have u tried another radio? Maybe it shit the bed
            Try checking your ground for the radio my loosened up so i put a lockwasher on it
            Wtb ek hatch pArts & gsr bolt ons
            Text 2038853014
              Where is the ground for the radio found?
                Sometime thru the connector or to the frame around the radio
                Text 2038853014
                  Put tha red wire and yellow wire together then put those to tha positive on tha battery then put tha ground (black wire) to tha ground on tha battery, it should turn on if not your radio is bad gl
                  I hate thieves wit a pasion, stop being some bums and get a job....
                    Thanks guys, the radio, ground, and fuses are good, still stuck
                      Get a test light and make sure ur getting power from ur harness
                        Is it possible to do that with a voltmeter? If I don't have power, what should I check?
                            yes u can check the wires for voltage with a voltmeter..accesory wire should have power when u turn the key to the acc position.the 12 volt wire should always have power..just test the radio liked mentioned earlier..remove it from the car and just tap the red and yellow wires together and connect them to the + side of a car battery and the black wire to the - side of the car battery.if the radio doesnt turn on,check for a radio fuse.if its not blown,your radio is shot.
                            Originally posted by knuckk
