A/C Delete Question?
  • A/C Delete Question?
    What's pop ctv.. Quick question.. I have a 95 cx hatch & am doin a complete AC delete... I have got the rubber block off for the firewall, but would like to know what heater box/core, & what AC delete/duct I will need? I was told all DX just would like to verify n make sure this is correct.. If there is anything else I need plz Lmk...
    BUMP if viewed plz
    ~D Block~
    Bump gl
    J.R. Built not Bought
      Would I be able to use any of my CX parts? Lmk ctv
      ~D Block~
        There you go pal honda parts now got em cheap
        There the same size for eg
            Type the part # on google it will take you in the right direction
              Thanks brotha.. I got the block offs I believe,i'm just confused on what air boxes do I need for behind the dashboard tho?? Like the trim.. An acquaintance of mine said DX.. I'm running it by you all to see if that is what I need
              ~D Block~
                u need a ac delete air box if u took the condenser out of the air box there will be a hole just put duct tape bro or u can buy my air box $20
                  where u located cuz im out worcester mass
                  ~D Block~
                    An hour away.
