Quick question about offset
  • Quick question about offset
    Hey ctv so i'm about to pick up some Enkei 92 for my hatch, but i just have a quick question about the offsets they come in.. Can someone explain the differences between +25 & +38.. Hope you guys can help.. thanks.. don't want a camber on my wheels would rather have them sit nice & flush.. i DO NOT want to go thru tires every 5k miles.. thanks hope you guys understand what i'm asking..
    ~D Block~
    Positive
    The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
      Negative
      The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
      If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
        so +25 is closest to the brake's,and +38 is even closer so the back of the wheel is even more toward the rear of the rim (a bit off center)
          but what's the difference between 25 & 38? is one going to cause more camber then the other?? i'm new to the whole offset thing with wheels on account i've been rocking my meshies for a while now..
          ~D Block~
            So what would i want on my eg hatch? +25 or +38?
            ~D Block~
              My hrad hurts after readin this guys posts...
              Go kick a boulder
                sorry to ask so many Q's.. just like i said new to all this offset crap
                ~D Block~
                  my posts?
                  ~D Block~
                      If i was u dont do anything lower then 25 unless ur gonna camber it
                      Follow Me On Instagram
                      Jdmkid618
                        ^allright so i'm better off going with +38 if i want to avoid camber wear/having to buy a camber kit..?
                        ~D Block~
                          I think i'm going to buy the enkei 92 +38 because i can throw them on without having to roll my fenders etc etc.. & if i ever want to widen them a little i could simply throw a spacer on em & roll the fenders that way.. correct?
                          ~D Block~
                            My head hurts after reading this guy post.
                              lmao
                              ~D Block~
