please close got it out thanx everyone
help please
Definetly should have never touched it until u took the crank pulley off first. You need a impact gun. Not all impact guns will take it off tho. I once spent a entire day trying to take one off with several impact guns.a torch will help. Heat the bolt up first.Originally posted by knuckk@jdmdikk only dude i would take advice from.
Originally posted by 203CARTEL_NeiL View PostWedge a pry bar on the flywheel to the block while someone else breaks the pulley bolt lose.. done this plenty of times. Make sure you soak the bolt with WD or PB.eh9 jdm b16
Pimpbays
