Thanx
C/F Hood Recleared
Originally posted by jd1 View PostGreat work!! I think he means like a step by step how you did it, what type of sand paper grits you used, what type of clear, how long did it take, ect.Ek coupe-dd
Daddy to be
Twisted Jokers Ac-Lieutenant
People wanted how to do it...here it is
1.wet sand hood with 400 grit sand paper till the clear is off.
2.wash it down.
3.wet sand hood with 1000 grit sand paper to get hood smooth.
4.rince it off and let hood dry.
5.after hood is dry apply first coat of clear coat(use good clear not that cheap walmart crap).
6.after that is dried apply second coat.
7.let it air dry and then its all set
It worked for me it should work for you..if u cant do it hit me up and ill do it for you at low costEk coupe-dd
Daddy to be
