dpfi to mpfi help
  • dpfi to mpfi help
    I got a 89 4 door civic need someone to do the dpfi to mpfi wiring ASAP hmu 2038502131 car has been sitting for almost 2 months cause nobody will do it for me please help me I can pay you
    IF I WANTED Z3 FENDERS I WOULD BE ROCKIN A BMW
    Car is also bseries vtec
      just google that shit
        Tried that didn't go over well
          How to Convert DPFI TO MPFI: A Wiring Guide SUPPLIES: 1 black 0BD0 ecu connector w/ pins 1 0BD0 MPFI engine harness Distributor plug w/ wires 1 0BD0 MPFI ECU 1 Injector resistor box (w/ enough wire to solder to) Various wires in colors close to factory colors as possible heat shrink tubing...
          !!!!!ThE GoOd DiE YoUnG!!!!!
            Bump this is what I wanna see..fukk or a post for a shell not to get rid of it..yo some one gotta know something we have the obd0 to ond1 jumper and it's not running right it's dumping too much fuel it hurts your eye too after a while..
            I<3my EJ8'CoUpE
              Bump quick and easy $200 for someone who knows how to do dpfi to mpfi b series swap
                Come on Ctv I know there's some one up hear that did this befor..let get my brothers ed3 running its spring and I know some one can use the cash..
                I<3my EJ8'CoUpE
                  Bump bump bump
                    bump someone help this man out
                      i can doit i think i have done to many of theses pm me location and you need a donnor harness to do it and i need the factory dpfi harness also. and if you want to run obd1 injectors i need the clips if you want to run obd0 injectors you need a resistor box.
                        My boy rhd integra 91 most likely knows how to do it.. hit him up..
