Transmission swap
  • Transmission swap
    I'm thinking about switching my auto into standard since I figure it would be way less expensive than doing a full swap.
    what would I need for a transmission swap?
    tranny , axles , ecu , clutch pump , clutch line , cluster , prob wiring harness depending year i think
      what year.. you dont need a harness but it makes it look cleaner if you are doing it to a 92-95 or on a intagra you need to get the mount that is welded to the frame
        I have a 93 hatch, how much u think a full transmission swap would run? I just want to know just in case someone tries to hustle me lol
          hmu asap 8605180263
          Go kick a boulder
            iight
              no much labor should be 400 + parts a sohc trans is cheap 200 buck or so need a linkage and the clutch peddle. buy the wend on mount form the dealer for about 30 bucks new clutch and flywheel. 200
                you would need pressure plate bolts transmission shift panel cuz auto is diff shift linkage with bushings n shifter manual starter half shaft axels flywheel cover clutch flywheel auto 2 5 speed mount clutch master cylinder slave cylinder clutch lines flywheel n flywheel bolts starter bolts 5 speed ecu rear t bracket n da lil shit like shift knob shift boot cluster is not necessary but it's up to you
                  thanks i appreciate the help
