anyone ever go to jdm engine depot ad get a motor from them..... i went the other day and picked up a full swap .... and shits smoking when i started it up ,,,, i had them do a compression test and everything came back with great numbers,,,, called them and they said they store the motors with some kinda fluid in them so no seals dry out...,,,,when i first started the motor is smoked bad , now its doesnt smoke at all til i rev it up to like 4500 rpm then its a little ..... i did a full tune up ...plugs ,wires,pcv, injector cleaner..... full oil change,... the smoke that is coming out of the car is a lite blue smells like oil but not burning it checked dip stick also i know iam not on the right ecu running a p2t... 99-00 si ecu and i need to be running it on a p73 but waitng on jumper harness to run it right ..... is there a chance that its just burning all the junk out of it ..... like the fluid they put it to store it....
jdm engine depot ....
Huh I just picked up a motor from them too n opened it up just to double check n everything looks good just minor stuff from sitting for a while but let's see ween I throw it in... But I would say drive it for a couple days with the right ecu let it clean itself out but don't beat on it n make things worseMoney ain't a thing! Crew Member #2
My cousin bought couple motor & swaps from them , never smoked & we did a compression check everytime we get a swap or motor , but it'd prolly cause it'd been sittinq maybe , just like egkid129 said , drive it'd for couple Days & see if it'd going away ,98Ex DD EJ8 ROADRUNNER
