motor swap question
  • motor swap question
    when putting a a motor such as a b18c which is jdm what harness would be the best to use in a 99 civic? obd2b? it seems like alot of plugs arent used and i wanna do a little tuck. any advice besides make a harness?
    EM1 860
    99 civic ex or si harness brother. make sure its 96+ and a jdm engine doesn't have crankshaft position sensor ..good luck
    Follow me @bolacan413
    Follow the build @k_insight
      just modify your harness you'll save loot that way. besides if you buy the swap online im pretty sure they come with a harness.
        which wont work cus u cant use a teggy harness on a 99 civic
          If your gonna used a 96-98 your gonna have. To do some mod to it ,
          98Ex DD EJ8 ROADRUNNER
            the harness comes with plugs on it
            he will probably need some
              his civic is 99 wont work
              ok now i understand u
                Well the best is to used the stock harness &&& mod it(save u money) which ur gonna have to anyway or (spend)get a si engine harness which should be plug & play . . .
                  ex or a si harness and then add what you need remove what you dont.
                    I got a harness LOL
                    D and G auto member #5
