got a 4 door ek that needs an alignment but pulls real hard wondering if its not the alignment and something bigger anyone got any suggestions on what else it could be ??
alignment problems??
One quick thing to check for is the tires. Abnormal wear or tread seperation can cause drivability issues. Also depending on the wear, that will tell you what geometry is out of spec and you can then check those components condition.4G63T Mirage.
Blk 99' Q45t.
And more.
You'll need to replace front lower control arms, get an alignment, and new tires.
My car was pulling really hard to the right and then the driver front lower control arm came out of place, so had to replace it, getting an alignment in a week or two.
Even though it dont have an alignment it does not pull at all.
