hey everybody just wondering im throwing a check engine light and my red maintenance light is goin off any way i was just wondering if any one has a shop or a ecu scanner around hartford area so i could check it out, i dont wanna drive to bakerz with this lmao
check engine light
Do it with a paper clip there's a brown or blue two prong plug right above the ecu in like a green rubber holder thing I guess. Stick a paper clip in the two hole and the check engine will blink. There's gonna be long blinks and right after short blinks. Ao if like like 2 long blinks and 3 short blinks that's code 23.
Here's the code list
-----CEL # List-----
0 (defined by CEL remaining on steady both without and with the service connector jumped) - indicates ECU power or ground problem when engine will not start; begin by checking the three main relay fuses and the G101 ground attached to the thermostat housing.
1 O2A - Oxygen sensor #1***
2 O2B - Oxygen sensor #2***
3 MAP - manifold absolute pressure sensor***
4 CKP - crank position sensor***
5 MAP - manifold absolute pressure sensor***
6 ECT - water temperature sensor***
7 TPS - throttle position sensor***
8 TDC - top dead centre sensor***
9 CYP - cylinder sensor***
10 IAT - intake air temperature sensor***
12 EGR - exhaust gas recirculation lift valve***
13 BARO - atmospheric pressure sensor***
14 IAC (EACV) - idle air control valve***
15 Ignition output signal***
16 Fuel injectors***
17 VSS - speed sensor***
19 Automatic transmission lockup control valve***
20 Electrical load detector***
21 VTEC spool solenoid valve***
22 VTEC pressure valve***
23 Knock sensor***
30 Automatic transmission A signal***
31 Automatic transmission B signal***
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater***
43 Fuel supply system***
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor***
54 CKF - crank fluctuation sensor***
58 TDC sensor #2***
61 Primary oxygen sensor***
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
I have it saved on my phone lolll
Originally posted by Santi View PostDo it with a paper clip there's a brown or blue two prong plug right above the ecu in like a green rubber holder thing I guess. Stick a paper clip in the two hole and the check engine will blink. There's gonna be long blinks and right after short blinks. Ao if like like 2 long blinks and 3 short blinks that's code 23.
23 Knock sensor***
58 TDC sensor #2***
67 Cat Converter
80 EGR Valve/Line
