Raise my strut towers....
  • Raise my strut towers....
    I need a shop to raise them so I can go lower. Lmk of a place to do this. Thanks.
    FCKMYLIFE.
    save the sohc!!
    Damn never herd of anyone tryin this but once ur done I want to see pix sounds fucking sick
      For your upper control arms ?
        Nahh like the whole thing strut and all my camber kit hits and my teins bottom out and I'm over it and still not even low. Im looking to go about another 2 maybe 3 inches lower. I'll put pics up of the towers and how low I am now
        FCKMYLIFE.
        save the sohc!!
          get top hats
          ~StayinFRESHSINCE1982~
          SPUNKY MONKEY CREW MEMBER #1
          203 CREW MEMBER #33
            Just buy koni race shocks and custom groundcontrols with extended top hats, i can lay frame if i want!
            NHSWAPS13203 > *
              Damm I never heard of this either but sounds interesting. I don't u can go too much lower cus u only have little room from the hood and the towers. But if u do do this post it up j wanna see
                the thing is the camber kit hits and im not into wearing tires like that. and i have ek hinges to raise the hood and ill cut out the support on that to mkae more room if needed.
                FCKMYLIFE.
                save the sohc!!
                  Top hats are ur best bet, destroying ur bay won't help for long you'll run into other issues n once cut it ain't easy 2 replace
                    im wrecking the bay as it sits now.
                    FCKMYLIFE.
                    save the sohc!!
                      I am this low now with eibach springs(Idk how to spell it lol) with no camber kit needed my tires r flat on the ground nd i can deff go lower
                      also what brand hood struts r those I want some for my cf hood but done want to spend more than 100 leme kno nd Srry for being off topic if they eBay idc just want to kno how well they work
                        they are ebay ones.
                        FCKMYLIFE.
                        save the sohc!!
                          yoo same shit happened on my last 2 hatches and im not even tuckin tire. i wanna go lower in the front so ive been wonderin how to fix it. keep this updated
                            So u think its the camber kits smashing on the tower I don't think stock ones will do this
                            Also do they work great have u had any problems with the hood struts blowing or anything
                              it is the camber kit hitting and i know ppl have said i they have no camber but are low. well i had alot!!!!! of camber before i put it in and id rather not go through tires. and iv had no problem with the hood lifts. the bracket moves alittle sometimes.
                              FCKMYLIFE.
                              save the sohc!!
