heres the deal im slammed all the way on my tein one peices and my tires are cambered in so im tuckin some tire but my alignment pulls to the right and if i switch the two front tires and put the one on the left on the right and visa versa then the car will pull to the left, i was told i needed an alignment but all the places are like....we cant do it your too low, lol guess i brought that on my self, but they also said u need like a camber kit or somthing....So im stuck lol it pulls to the right like a bitch and i just want it fixed, any one have any ideas
help tire alignment??!!
I also do alignments and if you are slammed on the ground. You will not be able to get enough adjustment in the front and may hit the apron with the upper control arm. Also it seems that you have a radial tire pull condition. That is what happens when you have a tire worn into a shape that causes the car to pull in different direction when switched from side to side(860) and beyond
#DavesTuning 8608050968
well i think u answered ur own question. u said if u switch the tires it changes so let one of ur boys with good tires borrow the front set and drive see what it does. u may have a toe in or toe out and camber that results in bad tire wear. try to get an alignment from one of these dudes and get a decent alignment. if u gonna get camber kits i would spend some money on them cus the ebay ones u cant slam ur car cus they hit the top of the strut tower unlike the better ones. im not alignment wizard so so giving ideas
armor all yur tires & wax yur car the problem shuld go away, the wax will help u cut the wind & the armor all will weigh down the tires so they stay in place goin strait =) when yur car looks better, it feels better & drives better. G/L
=)Originally posted by kemar24psimario jus hit me wen your car done im waiting for u to see my tail lights.
Originally posted by EG_Luny View Postarmor all yur tires & wax yur car the problem shuld go away, the wax will help u cut the wind & the armor all will weigh down the tires so they stay in place goin strait =) when yur car looks better, it feels better & drives better. G/L
LoL~StayinFRESHSINCE1982~SPUNKY MONKEY CREW MEMBER #1203 CREW MEMBER #33
