95 GSR w/b16 tranny in a 94 Bubble Question
  • 95 GSR w/b16 tranny in a 94 Bubble Question
    I have a 95 GSR w/b16 tranny in a 94 Bubble Question? as stated above.
    I need to know how to pull codes from it. Where is the jumper harness SUPPOSED to be located. Cuz I checked all around the ecu And did everything short of unscrewing it and pulling it. Is there another place it would be besides near the ECU??
    my car
    is right by the glove compartment
      There should be too green plugs.
      WILSON BUILT
        What they said, two plugs, one is a 3 wire, the other is a 2, the 3 wire is for hooking up a scanner to it, the other one is for jumping and reading the codes manually.
        2004 Accord DX
        2005 Ruckus
          thanx for the INFO
          Im check it Out -T
            Ok So I pulled a code 17- VSS code 22 vtech oil pressure switch- but this code comes on Ive heard if your vtec stopped running. Ne truth??? Sounds like I just gotta replace the Vehicle Speed Sensor.
