!!!!Help with swap!!!!
  • !!!!Help with swap!!!!
    i want to swap my f23a4 with a f20b. What would i need in order to so this swap?? I know i need new motor mounts and ecu, but is everything else pretty compatible?? Will my tranny hook up to the f20b?? Thanx for any help you can give.
    2000 accord lx
    hey bro.. im not sure but try posting on f and h series tech.. yuh might be able to get a little more help there... good luck!
      If im not mistaken the tranny does bolt right up. As far as everything else if your f23 is vtec then you dont need to swap the harness. And everything else is just the little things like you already have listed.
