Spark plug tube seals STUCK!
  • Spark plug tube seals STUCK!
    wana paint my v/c but the spark plug tube seals are stuck in and I cant get them out. I got picks and i heated the whole thing up over a kerosene heater but they arent budging, just chipping little by little but the bulk of it is still stuck in. any good ideas to get these mofos out?
    http://jdmchicago.com/forums/showthread.php?t=20513
    You use a large flat head screwdriver and jam it between the base of the seal and recessed area on the bottom of the VC, and just pry it.. You're not the only one with this issue, Joel actually couldn't figure it out either.
      what the guy Jason above said always works for me.
        To install the new ones, use the old seals you just pryed out and place it over the top of the new one and tap them with a hammer almost in a criss cross pattern so it will go in evenly.
          thanks, ill try it but i was trying screwdrivers as well, obviously haha. but ill see if that method works after i get outa work
            large flat head or small prybar. I've done enough, they don't come out easy.
              You must put it between the seal and vc coverbbevuase in that seal is like metal and bends easy
                Oh, Weston, it's Doug by the way.
                  you need to use the screwdrive trick go from behind and wack it and it will come i have alot of extra sohc valvecovers i can sell ya so you can paint any color you want
                    haha what up doug! yeah well ive never had them stuck this bad before but ill try anyway
