need opinons on why this car wont start
  • need opinons on why this car wont start
    my bro put a engine from chuck and eddies its a integra ls i checked timing , compression, spark , there is fuel because i can smell it flood after a few times trying to start it, i cant figure it out the wires are all connected right im going to check out some more shit lmk what you think
    bad crank sensor
      good looks im goin to check out in a few
        Make sure you check all your grounds also
        RIP Nick Haines 13203 Gone but never forgotten
          car has an alarm or kill switch?
            i checked grounds sanded the shit out of them im not to sure about alarm its not my car but it should cuz it has power windows and shit but im not sure
              Sounds like the dizzy because that's the same issue I had on my sohc
              mr.snuggles to you bitch
                yours still had spark
                  How much did they charge you for the ls?
                  R.I.P Nick aka NHSwaps
                    I had spark and everything but it was turning over fuel was coming out new cap and rotor didn't work I change the dizzy and bam its alive lol its the dizzy bro I thought it was the grounds but it wasn't all 3 were good lol or what ever but change that dizzy bro I know that for sure I had the same issue as you it was back firing in my intake and everything so I know bro
                      u kno almost all tha time... u dnt gotta buy a whole new dizzy... its just tha coil... obd1 n obd2 are all exactly tha same.. u can actually cut tha obd1 plugs off n put them onto tha obd2 dizzy n itll werk perfect... just som info for next time... dizzys are expensive as fuck..
                        if you have spark and fuel check your firing order.
                          X2
                          "If yah can't find em, grind em"
                          RIP NICK
                            Sometimes you do because I had a bad dizzy change the coil didn't work brought a new one and work like a champ plus you can buy a used one if you know its good bro
                              it was the dizzy i swapped my obd1 to it and it started first try
