need some help/advice
  • need some help/advice
    i have emmissions due and im worried about passing .. i have a JDM motor , turboed , with a fulll straight pipe exhaust with no cats no nothing, with a very rich tune.. ive read that fuel additives can help you pass, but i dont know much about emmisions. and btw it's obd1, (1995)... and 1 got any tricks/tips for passing?
    yo bear you ever pass? my 4dr failed twice but i got a waiver for it thats good for a year since i spent over like 740 on repairs.
      Where did you have your tune? In the OBD1 chipped ECU? Why is it rich? That's not good for your motor plus is not good for your pocket unless you don't pay for gas.
      Anyway if your tune is in the ECU just make the ECU to run the factory setup and install a catalytic converter in your exhaust.
      That will be enough to pass emissions.
      Maybe you will also have to install the factory fuel injectors. But that's a maybe.
      Apply it!
        if u kno someone wit ur same car borrow theres and jus bring ur registration problem solved
          Where its that ^^^^^
            WRONG they check the vin number on your car and if it dosent match in the system they dont pass it..i tried it last week and i got a letter that i need emissions done
              Lol swizz I'm boutta do the same shit
                Originally posted by vtecboost View Post
                wrong they check the vin number on your car and if it dosent match in the system they dont pass it..i tried it last week and i got a letter that i need emissions done
                x 999
                Apply it!
                  what year is the car?
                  OBD1 they'll put on the rollers with a sniffer up the exhaust. you need a cat to pass at least the visual inspection.
                  OBD2 as long as there is no check engine lights, and the emissions machine can communicate with the OBD2 port, you'll pass.
                  590852836f5fbce940_b
                    without a cat they'll send you home. so thats the first thing you gotta take care of.
                    http://jdmchicago.com/forums/showthread.php?t=20513
                      He said it's 1995 here:
                      So yeah it is OBD1 so he will need the cat.
                      Apply it!
                        unless he got a 25 yr car with OBD1 setup, haha, thats trick
                          throw a cat on it turn off boost put it on a stock basemap
                            i gotta obd1 on a obd2 car, so i put the stock ex ecu (original shell ecu), make sure u got no check engine, and go for it
                              I say uou just trade for my 98 hx coupe :)
