Emissions Test
  • Emissions Test
    i need 2 go thru emissions..anybody here run tha test ill def hook u up wit sum cash or some place where if i pay a lil extra they will pass ?? lmk asap
    knuckk.
    anybody??????
    knuckk.
      i am a certified tester...umm what years ur car??
        pmed you bumpppp..
        knuckk.
          nigga i went to emissions all they did was plug something in no CEL and i was on my way buy a newer car haha
          203CARTEL_John$
            yea all they di id plug a connector into the obd port on newer cars if you have a check engine light on it will not pass and u cant even clear the code it will abort the test because of the readiness monitors
              anyone still runs these test?
              knuckk.
                i need this ish done my check engine light is still on
                knuckk.
                  you don't need to pass emissions to register your car....
                  just bring the failed paper with the rest of your documents, and register it as normal.
                  (203)
                  Pans: 3
                  Pumps: 2
                    but then it will expire after 20 days...its only temporary ur registration will get canceled.I belive you only get temp plates to.Why dont you try fixing the problem????what year is the car and what code(s) is it throwing?
                      niggaz aint rich lol ........ but see what codes u throwin
                      " Mr. Tough Guy "
                        well i dont have the map nor the tps sensor plugged in cause someone did my harness and i cnt get in touch with them but i was seein if anyone knew hot to bypass those cause i need my emissions done asap
                        knuckk.
                          i dont have temp plates the dmv gave me regular [plates but they gave me 30 days to get it done i dont have the tps or map sensor plugged in and i cnt plug it in cause the wires r too short
                          knuckk.
                            then extended the wires lollll
                            " Mr. Tough Guy "
