tell me what u think
  • tell me what u think
    what do you think?
    bump for another coupe .....is this your build??
    The Power of Dreams
        Don't like the sprayed grill (upper and lower), need to get the moldings on there, and line everything up. Respray the grill's black when you are done, get everything on there straight, put an engine/trans in, get some wheels and some drop and won't be bad at all.
        My work: Flikr.
          i think thats primer if not idk
          The Power of Dreams
            i hope its primer. cuz that paint honestly doesnt look very consistent. the drivers door doesnt match the rest of the body
              Looks like spray paint.
                This back yard look familar
                "If yah can't find em, grind em"
                RIP NICK
                  is that base or spray paint... cause the car doesnt match... put another coat and make sure its base then clear coat that hoe 3 times... but its ok its not finished so cant really judge
                  Hondakid860
                    thank you what you see is the under coat 2 try to get it white....
                    next coat will be bright @ss white with a pearl white over the top layer
                    and then.......
                      not bad, ive seen worse, and that from people doing it in their garages!
                      ~StayinFRESHSINCE1982~
                      SPUNKY MONKEY CREW MEMBER #1
                      203 CREW MEMBER #33
                        and then.......
                        oo ok. well then this looks fine. but lets see this thing when its done!!
                          yep
                          203 CREW MEMBER #33
                            im doing in the open dusty a$$ yard
                              no wires besides the box
