Advice needed
  • Advice needed
    close
    turbo
      Turbo, are best bet for ls builds
      98Ex DD EJ8 ROADRUNNER
        In my experience ls motors are trash. Buy a gsr if you're trying to build a stock motor turbo car, or build the ls bottom and throw a vtec head on it.
          i would go SC sleeper!
          J-ROC TUNING
            Turbo, Ls is ok. It's hit or miss with them deff recommend arp rod bolts and headstuds if going boost they tend to eat rod bearings in my experiences.
              Turbo all the way
              Fuck friends crew member #8
                turbo all day. just rebuild the bottom end and put new arp head studs.
                  turbo
                  Superchargers are best suited for applications that require a lot of flexibility and torque, such as autocross racing. Since superchargers essentially make the Civic's small engine act bigger than it really is, they're also good for quick passing maneuvers from medium speed, pulling steep hills and powering out of tight curves. Turbos are more appropriate for applications where the engine is unlikely to drop to low rpm, like drag racing, top speed racing and on real racetracks without a great number of low-speed hairpin turns. "
                  and also the fact that it revs up to 8k, it can produce more power with the turbo for a cheaper price.
                    turbo ls vtec
                      Right now i see this as 90% of people say turbo while 10% say superchargers
                        Thanxs for all the advice...Decision made ls/vtec turbo!!! close thread
                          i got a b16 tranny if you need 1
                            how much?
