need help... how do i take out broken lca bolts ??? the head popped right off...
lca bolts broke..
on the back of them there is a fixed nut. what i did was with a cutting torch i cut the bolt off the back and it came right out and just went to the hard ware store and found a nut that fit on the new bolt.
or you can try to drill through them but your going to need a real good drill for that.
