Need help asap
  • #16
    Originally posted by jdmdikk View Post
    its the distributor coil bro..it doesnt matter if its fine 1 minute and the next its fucked,.swap the coil out..u have to remove the cap and the rotor(circle spinning part) and then the coil is the big part inside with the spring on it,its held on by two philip screws and has 2 wires connected to it..if its not that then check your ecu fuse but i am 99% sure that its the coil..i have 1 if u need 1
    Yessir sounds like what this guy said. I doubt ecu fuse is shot if your getting fuel.
    • #17
      Thanks for the help guys. And bro will it work for a type r? If so yes I want it and ill buy it off you. Just don't break my bank lol PM me!
      -Fusco_
      -*203*
      -DaiLy: 95 Integra Type R SwappeD !
      • #18
        pm sent..
        Originally posted by knuckk
        • #19
          something in tha distributor got fucked up... check all connectors on tha internals and mayb replace them...
          • #20
            check all ur fuses.and alternator that shit happend to me it ended up bein a fuse
            USMC
            • #21
              I was just picked up a dizzy ima see if that works
              -Fusco_
              -*203*
              • #22
                check your igniton module inisde the distributor that creates your spark. thats probably gone check it out
                FAKE ASS NIGGAS ALWAYS GET OUTLINE WITH A WHITE CHALK
                • #23
                  crank sensor ?
