WHICH tranny fluid shuld i use?
  • WHICH tranny fluid shuld i use?
    honda MTF? or redline or mobil 1 MTF ..im prolly gunna go with honda MTF but just want some feedback??
    -Fusco_
    -*203*
    -DaiLy: 95 Integra Type R SwappeD !
    gm synchro mesh friction modified
    !!!!!ThE GoOd DiE YoUnG!!!!!
      Yeah I've heard of that but where do u get it?
      -Fusco_
      -*203*
        i used the honda mtf and i noticed smoother shifting
          Any gm dealership will carry it but make sure you ask them for friction modified
            You could go to anyparts store and buy Pennzoil synchromesh fluid. Its in a yellow bottle and I use it when I cant make it to the dealer.
              oil
              Follow me @bolacan413
              Follow the build @k_insight
                i would use the gm mesh if ure having a little grind and looking for a quick "fix". Hondas manual fluid is to thin it feels like water. dont waste money on mobile1. Saddly enough just use 10/30motor oil man.
                My transmission's went 9's
                http://youtu.be/z2PHemIp_Tg
                  If your trans is junk or on it's way out use synchro mesh. If your transmission is solid than give it the good stuff (honda mtf). You can get it from the dealer and it is a bit spendy but worth it imo. Also you can use 10w30 in a pinch but if you are doing it rite get the honda mtf.
                  My work: Flikr.
                    use Honda MTF new formula is better than Gm syncromesh make sure you ask for the white cap green label which is the new formula
                    203CARTEL_John$
                      X2 this guy knows what hes talkin about
