What should i do Sell my B swap or go K. Im really confused on what im going to do. I have so much money in my b i could have just gone k. Heres the spec of my engine. So should i stay with turbo b or go K
18c block
b16 head
ctr cams
Cp pistons
Manley h beam Rods
precision 650cc injectors
turbonetics 50 trim turbo and down pipe
drag gen 1 manifold b series cast
38mm tial wastegate with race valve
greddy type s bov
xs power intercooler for now
omni power 3 bar map sensor
aem fpr
walbro 255lph fuel
Arp flywheel bolts
GE headstuds
oem headgasket
gates timing belt
all genuine oem gaskets and pumps all new
calico coated bearings acl race bearing.
supertech valves,retainers,and valve springs
supertech valve seals
blox cam gears
s9b lsd trans 4.2 final drive
innovative mounts
ngk spark plug wires
p28
itr throttle body and intake mani
cc stage 4 clutch.
18c block
b16 head
ctr cams
Cp pistons
Manley h beam Rods
greddy type s bov
aem fpr
walbro 255lph fuel
Arp flywheel bolts
GE headstuds
oem headgasket
gates timing belt
blox cam gears
innovative mounts
p28
cc stage 4 clutch.
