The first thing you'll observe when you are tired this year is after a long run , your athlete will typically need to rest. If a Madden 25 coins player wants to play the same player for every game of their drive, they'll be able to see that the player may be subbed out when they have landed the ball multiple times in one row. This gives more value to back-up running backs as well as receivers.
The game gets more intense,, you will observe that the player who has been carrying the weight all game long will need to take a few more breaths which means that players must make use of their timeouts, and will not be able to use their best players as much. On defense, players aren't allowed to play an D-Lineman, and then use as an Safety or Linebacker all game. Defenders get tired more often, and running around the field in your best defensive lineman is likely to lead to him playing more active on the field.
The most obvious Stamina ratings differences are at areas like the RB as well as DE positions. Large bruiser backs such as Brandon Jacobs will have less Stamina than smaller backs within the league. Players who are substituted often on Sundays such as Marion Barber and Willis McGahee (and other RB's who are on backfield committees) are also less Stamina ratings as compared to other starters, so you'll notice these players being subbed out more often.
Defensive Linemen who are subbed more often or are only subbed for specific circumstances (i.e. pass rush on 3rd and long) on Sundays, such as Raheem Brock as well as Adewale Olugunleye are also lower Stamina ratings, which means they are more likely to be used as situational players rather than full-timers.
What is the best way to help an Madden 25 player not have fatigue problems, other than the complete elimination of fatigue? There is an option to adjust the slider within My buy Mut 25 coins in Game Options that ranges from 0 to 100. The default setting is 50. However, if the user thinks the Fatigue is excessive it isn't necessary to turn off the feature completely since they can turn the slider down until 10. If they believe it's an a bit over the top, they could reduce it by 40. The player can alter their slider till they attain the feeling they're trying to achieve to enjoy the experience they desire.
