About how much power?
  • About how much power?
    About how much power wld this setup make?
    D16y7
    turbo kit t3/t4 on 5 psi
    cam
    pistons
    injectors
    walbro fuel pump
    and a tune of course!
    Thanks in advance ppl
    White ek hatch
    Somewhere Around 430-460 WHP....
    S14 Zenki.
    Mayhem Autoworks.
    Hubbard Park Pizza.
    EST Motorsports.
    MBFilms.
    United States Marine.
      lol talking nonsense
      97 Boosted Hatch my toy
        Hahahahaha...Shoulda Played Alonq Man, Ruininq All My Fun.
        S14 Zenki.
        Mayhem Autoworks.
        Hubbard Park Pizza.
        EST Motorsports.
        MBFilms.
          It's not really easy to say, the car would need to be tuned first and dyno. With single cams, they can be easily making 400hp with all the works done to it. But in my guess I would say 250-350hp.. Just don't half ass the build, and I realized you focused more on the bottom block. The head also needs the same work as the bottom would need.. And you need good injectors, because I noticed that was not on your list.
            I'm jus thinking of doing something simple this is for my next car which I hope I can get ok so I gotta add injectors to the list wat else?
            White ek hatch
              fuck y7s... nonvtec ftl... build a z6
                Bout how much hp were u pushin wit the del sol?
                White ek hatch
                  A turbo y7 wld def beat ur si hahaha
                  White ek hatch
                    lmaooooooooooo
                    R.I.P Nick aka NHSwaps
                      Well your going to need:
                      turbo
                      3inch down pipe and piping
                      intercooler
                      blow off valve
                      piping & couplings
                      tbolt clamps
                      low compression pistons vitara is a good choice for the single cams
                      cometic head gasket
                      apr head studs
                      6puck clutch
                      ngk bkr7e spark plugs gapped at 0.30
                      the list goes on, Im missing some things but someone else will add on. But just don't half ass and buy knock off brands like eBay. Do it the right way and all your money won't be in waste.
                      boost gauge
                        I was pushing 360hp easily, and I had more boost to build.. And I was spanking ninjas left to right like the em1, the prelude, the dc2, miss jdms fg except my coupling poped off.. But the only problem I had was turbo lag in second gear.. That Fawked me up on some of my runs.
                          5psi?? you lucky if you break 200
                            Yeah 5psi is nothing, If you are putting work on the motor then you can turn up the boost past 8psi. Unless your not going to build your motor right, then keep it below 8psi.. Btw, it doesn't matter about how much psi you have, it matters on your horsepower goals. Because psi doesn't tell you anything, horsepower does. You need to make a HP goal first before you start your turbo build. Or else your going to run into problems like blowing up your motor and fixing things here and there. And that way you will have a reliable build!
                              My goal wld only be 200 I wld be happy with tht!
                              White ek hatch
