O2 sensor idea
  • O2 sensor idea
    I have a lil crazy idea... I have a test pipe on my car nd my car takes 2 o2 sensors cld I hard wire the o2 sensor in the back to the one connected in the front nd my cel will go away???? Jus a thought
    White ek hatch
    idk try it and get result's
      instead of doin all that all you have to do is get 2 spark plug anti fowlers from autozone and drill one out then screw the 2 together and install into the rear spot thats what we do for the evo's and sti's it reads a differnt reading and wont throw a check engine light
      94 coupe gsr turbo-sold 98 coupe h22-stolen11 Denali- Daily
      01 ITR #37-project
        why dnt u just get another O2 sensor and put it in. Don't hack shit!
          i think it would throw a code because ones in front of cat ones behind theres a diff reading after the exaust goes threw i think if it read the same it would say ur cat is bad nd throw a c.e.l.
            Ur not getting it lol the o2 sensor is in but it's in the test pipe nd it's throwing a code I'm wondering if I jus wire it to the one on the header will it still throw a code
            White ek hatch
              I really dnt understand what ur sayin lol ur sayin get those 2 things nd put it where the o2 sensor goes on the test pipe????
              White ek hatch
                yes it will raise it out of the flow of the exhaust and if you space it right it will trick the ecu to think the is a cat there slowing down the flow
                  Oh ok
                  White ek hatch
                    Basically theres no way in cutting corners, its ether add the cat and have no check engine light, or have a test pipe and have a check engine light.. Just put the cat back on, its not like your doing serious racing or anything, unless you are..
                      Even if you are you are loosing one or two hp with a high flow cat. You can pick one up for cheep on ebay.
                      My work: Flikr.
                        o2 simulator
                          Add an extra 02 sensor for 10hp more .. Good luck on sale
                          *S14 Kouki *
                            you need a mechanical o2 simulator megan makes one for 20 bucks so does blox.this is a angled one.
                              o2 simulator
                              This
