CTR crank pulley
  • CTR crank pulley
    let me know wat u guys think of the CTR crank pulley for my stock ls. i heard that its 1.9 pounds compared to the stock crank pulley, which is about 10. and i also heard thats its bad for the oil pump because of the viberation. i know i wont have ps or ac any more, but thats fine. let me know if i should get it.
    Wouldnt recomend it on a ls motor. unless u have the motor balanced
    Originally posted by 95ejvtec
      I heard Honda Motors Came balanced from the factory?? is this true b/c I know someone who was going to do the same....just trying to figure it out
        they are internally balanced from the factory but can be balnced to even closer tolerances. but either way they are all internally balanced and ive been running a R crank pulley with no problems.
          thanks, thats what I figured..
          you are talking "closer tolerances" like blueprinting and balancing the engines??
            i was runnin an r pulley on my ls wit no problems
              yeh the rods and pistons can be balanced to exact same specs for high rpm use. they just basicly make all the parts weigh exactly the same.. ie. rods pistons crank
                If you like your oil pump keep the stock one
                (860) and beyond
                #DavesTuning 8608050968
                  how would it hurt the oil pump?
                    Honda would not have produced it, if it was not affective.
                      x2
                        bump!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!my shit!!!!
                        yooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!
                        i need trannys asap broken ones will pick up and drive for trannys!!!!!!!!hit me up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        b series only !!!!stick!!!!!5 speed !!!!!!!!no auto's please!!!!!!!!!!!!!gears and parts also!
                        hydro or ys1 cable ,only!
                          ive heard the ctr pulley is balanced bu isnt dampened..but this is just what ive eard,i was also looking into getting one,so ayone have any suggestions?
                          !!!!!ThE GoOd DiE YoUnG!!!!!
                            well i would suggest change the oil pump then get the CTR pulley... but not sure. at least u dont have to worry about the oil too much.
                              i got a few but just for making these posts everywhere i'm not gonna sell you one
