B series pistons???
  • B series pistons???
    Gota buy high compression b series pistons for my itr b18c5... what should i get perferably not spending tooo tooo much lol thanks
    I Love Blunts N B!tches Crew Member #1
    I Love Haters Crew Member #2
    I Hate Low Ballers Crew Member #2
    :p:p
    $XBOX 360 GamerTagz$
    Spinach Rav
    Im Flithy
    Gag On My Glock
    Pistons
    either way if your tryin to buy aftermarket pistons its gunna cost you a few bucks but je or areies are good
    Build In The Making!!!! BackYard Built Not Bought!!!!
      CP Pistons
      You can't fix something if you don't know how it works
        I agree with everything that was stated already, but aftermarket pistons are going to cost you obviously. If you get aftermarket pistons I would recommend getting some aftermarket rods; Eagle or Manley. If you want to go an inexpensive route, stick with OEM. I personally like P30 pistons and they will net you a bit higher compression than your stock ITR's. I've never been a fan of CTR pistons due to the high amount of static compression you gain and their dome height, but it is another option you have.
          cp or je best for buck
            Originally posted by it0sls203 View Post
            I agree with everything that was stated already, but aftermarket pistons are going to cost you obviously. If you want to go an inexpensive route, stick with OEM. I personally like P30 pistons and they will net you a bit higher compression than your stock ITR's. I've never been a fan of CTR pistons due to the high amount of static compression you gain and their dome height, but it is another option you have.
            X2.. P30's FTW!!! Super Cheap & give you a nice Bump in compression. $200 for all 4!! PR3(USDM B16) & PCT(CTR) Pistons are other cheap OEM Piston options.
              Thanks guys it only took me over a month to get feed back haha
              :p:p
              Spinach Rav
              Im Flithy
              Gag On My Glock
