ok i have a super clean d16y7 when i mean clean its clean they only have 105 hp some were around there. i was wondering will i spend more money swapping for a b or an h. or just build the d
D,B or h
No I no a lot bout Honda's and it a ej7 all I wnt to no is all the money everyone puts into swaps just to drop the motor and transmission in will u git more power out of the d by using the money just wnt to no ruffly how much do u have to spend for a b swap
me personally would keep the d n build it but ur gonna end up spending more money on buildin the d then if u got a jdm b series motor n built it a lil bit.. it all depends on wat YOU want. its ur car do it how you want it. just keep in mind wat u wanna do to it. turbo, n/a do ur research n make ur decision.
Turbo the D! Start small. Then of you need more power. Build the motor to handle more boost. If I had car with a strong running D engine that's what I would do. Might end up spending a little more in the long run but it will not be all at once and a nice front mount will look real good too.i made a pixelcar for my sig but i'm too lazy to pm a moderator.
Originally posted by t-honda72 View PostWhat's a good size Turbo to start of with
