need some help..
  • need some help..
    ok so i've kinda run into a problem doin a swap.. im throwin in a y7 in my car.. n i guess the y7 n the b8 that i had.. have diff axles so i need new axles im guessing... Also big big question.... will the d15b8 wiring harness work with my d16y7??? i had a z6 intake mani on there and the wiring harness had way too many plugs.. anyways i put the old d15b8 intake mani on n it's lookin a lil better... already swapped the alt, injects, fuel rail, dizzy, n i got a p28 ecu... im just kind of stuck.. seems like im runnin back and forth to the part store for somethin new... so i'm just trying to find out exactly everything i need...
    Bump if viewed please
    Bump some one help this dude if it was a b. I would be abel to help g/l
    1993 rhd civic eg type r
      ^ good looks anyways... anyone?? i really need to get this swap in..
        Ttttt
          Yes your harness will work as long as you change the alternator, distributor, and injectors which you already did. And as for axles get ones for a y7 and they'll fit right in.
            thanks for the input bro.. glad to hear my harness will work..
              Alright... so here's a little update on my progress... got the engine dropped in everything hooked up... everything seems to be straight.. but when i go to start it.. absolutely nothing.. idk whether it's a problem with me using the (b8 wiring harness) with the y7 motor... that's what my boy is trying to imply.. but i swapped alternator, dizzy, fuel rail, injectors already... so it should work.. idk possible suggestions of what the problem may be???
                Tttttttttttttt
                  anyone got any type of suggestions?????
                  bump if viewed plz
