at what point on a build do you or should you upgrade injectors? idk how much of the duty cycle (yeah i said dooty) im running or wha.tever. i was gonna get a set of 550cc's but my mechanic said i shouldnt really need those.
fuel system
I'd go bigger then 310's. That'd be like pushing em. I would go with atleast 370's. But what'd be pretty easy/cost efficient. Dsm 450's. They go from anywhere between $50-$120. And then when the tuner tunes em he can change the duty cycles to as needed. i'd rather have bigger injectors with lower duty cycles then smaller injectors maxed out.
Check out the for sale section. "Mark" has a set for sale.Money ain't a thing! Crew Member #1
