d15b7 help
  • d15b7 help
    i recently bought 95 eg hatch and wanted to take a look inside the head to make sure everything was in good shape but when i started taking the bolts off the valve cover i got to the front left nut and realized it was glued on so now i cant take the valve cover off. Does anyone no how to extract that head bolt and replace it with a new one so i can take the head apart plz help i need it bak
    thats not a head bolt if its only holding on the valve cover its a valve cover nut and if you cant get it off all you would have to do is replace that cam cap bolt
