What are people runing for oil?
This is a sticky topic.
  • #16
    your not susspose to go back to regular oil once synthetic is changed because it will wear out gaskets faster. gaskets absorb oil over time and almost get use to a kind of oil.
    RIP Nick 13203
    • #17
      THAt's true... I can't use rp in my engine cause I use regular oil.. But once I redo all my gaskets I might go with rp
      cripple member : P
      • #18
        As for hurtin the motor by going back to regular oil, it wont happen. The motor itself will be ok. Gaskets tend to go cuz of the detergents used in todays new oils. It all depends on how old your gaskets are.
        • #19
          And now they are putting more and more detergents in regular oil. ex: STOP THE SLUG!! that you see on TV every day.
          • #20
            To the top^^^^^^
            • #21
              i just use mobile 1
              • #22
                Originally posted by Chillmatic View Post
                i just use mobile 1
                Mobil 1 is also a very good oil.
                • #23
                  I use penzoil the yellow one...even tho my engine only has 95k lol
                  cripple member : P
                  • #24
                    Royal purple 10-30 on the engine and tranny
                    S3-R
                    Stage3-Racing
                    • #25
                      The oil I use day that lol
                      cripple member : P
                      • #26
                        I use Eneos 5w30 with hamp oil filter. You can mix regular motor oil with synthetic but it will take away the properties of synthetic. So no it's not good. Synthetic is good for those cold start ups because it leaves a light film on the engine components. Mobil 1 and OEM Honda filter is a good combo too.
                        • #27
                          For MTF HONDA grey bottle, green label with the white top ftw!
                          • #28
                            That high mileage oil swells your gaskets so they stop leaking!
                            • #29
                              i use peanut oil
                              • #30
                                autozone 30weight!!!!!!
