DIY: Port and Polish
  • DIY: Port and Polish
    My idea of port and polish
    Kinda a DIY:
    One way to do it without a flow bench is by first disasembling the head, and cleaning the entire bare head. Then do you porting and polish by hand with 180 sand paper and oil for lubricant. Port out two ports at a time, constantly putting the valves springs and retainers back in to measure out big the port is.
    How you do this is:
    After putting the valves spring and retainers back in and making sure with a vaccum gauge (a vacuum pump works best but a hand vacuum pump will do just fine. Once you have 17-21 in/hg of vacuum on both ports you fill both ports with water to the top (level with the top of each port). Then measure by pouring out or removing the water in each port and measure the volume of the water. Once you have to ports that have the same amount of water in them you know that each port is the same size.
    I know this sounds very time consuming and tedious to do but professional port and polishing does cost quite a bit. So for all those who are really motivation and like those small project like i do( ps this is a pretty good way (in my option) to do it for cheap.)
    Let me know what you think!
    Thanks!
    The Honda head in these pictures is a B20 JDM head and its the first one did:
    Webshots, the best in Desktop Wallpaper, Desktop Backgrounds, and Screen Savers since 1995.
    1991 EF Hatch - SOLD
    1999 EK Coupe
    1991 EF Hatch D16Y3 - Parted Out....Gone!
    1993 EG Coupe LS - SOLD and MISS
    I Love My Honda!!!
    WTB parts search my threads!
    sounds good.u should post pics on step by step
    Originally posted by knuckk
      x2
        now i will agree your doing good work..
          injen782 - thanks just for that ill do a head for free for you!!! hit m,e up 609-661-8314
          jdmdikk and bones4 thanks your two let me know if your need help on anything i mean it
          1999 EK Coupe
          I Love My Honda!!!
            also i plan on making this diy huge, just give me time, work in progress in progress, need heads to do lol i like doing them
            1999 EK Coupe
            I Love My Honda!!!
              i still got the 2 ls heads whenever you want them
                head looks good.
                Looks like you took your time and put alot of work in.
                R.I.P NICK a.k.a NHswaps13203
                  There is no need to polish the ports, fuel needs to hit the ruff port so that it can jump around and mix with the air, thats how power is made! Removing casting defects is about all you need to do.
                    i disagree..fuel i misted into the port,not just sprayed.so it mixes as its in cycle
                      ^ and I disagree with that, but it's ok^
                        Still waiting on you to get back to me on the single cam head that I have
                        RPM's =Ruins Peoples Motors
                          Want to do a sohc head 4 me?i have to replace a valve so i figured y not n its a chance for u to gain a little more experience..lmk
                            Originally posted by vdkk View Post
                            head looks good.
                            hell yeah that first b20 head took me like 45 hours lmao
                            1999 EK Coupe
                            I Love My Honda!!!
                              also i do heads just call me 860-392-8517, its a much better way to get a hold of me
                              1999 EK Coupe
                              I Love My Honda!!!
