I was lookin at itb set-ups and came across an accord with the head turned 180 degrees. check it.
flipped head
the motor is not backwords the head was fliped the other way but there was mega money involved if you read in to it...
since the head is on fliped the motor runs clock wise (reg ran counter clock wise) so new cams had to be made a stand alone computer set up. a one off tranny since the motor is spinnin backwords to normal the stock tranny will not work or it would have 5 back up gears and on fowardRIP Nick
Originally posted by sikciv666 View Posthead isnt turned the motor is, its like a K, where the trans is on the drivers side.RIP NHSWAPS13203
