ls vtec help
  • ls vtec help
    i have a 00 ls block with a 96 gsr head also a gsr tranny.. i want to put cams and pistons but dont know what kind to buy and will be spraying about 50-75 shot.. thanx for the help.
    not trying to be negative, but i'd be very careful about sprayin a ls/vtec unless its built by a pro... my buddy had an ls vtec that he put together himself, and running it n/a it still blew up like 3 months later..
    860 #27
      Use some PR3 Pistons with SKunk 2 Stage 2's, or Pro 1's. I would normally say to run P30 pistons but, if you plan on spraying, it would shorten the life of the 12-to-1 compression
      motor. Just my opinion.
        if i were u ill just boost it or stick to all motor
        TURBO 2001 IS300
          kungfu university
          Welcome to www.kungfuuniversity.com! Here you will find what is Kungfu, how can learn Kungfu well, how to be a man just like Bruce Lee, Jackie Chan and Jet Li!It's said that Gongfu. Hard work over time to accomplish skill. A painter can have gongfu. Or the butcher who cuts meat every day with such skill...his knife never touches bone. Learn the form, but seek the formless. Hear the soundless. Learn it all, then forget it all. Learn The Way, then find your own way. The musician can have gongfu. Or the poet who paints pictures with words and makes emperors weep. This, too, is gongfu. But do not name it, my friend, for it is like water. Nothing is softer than water...yet it can overcome rock. It does not fight. It flows around the opponent. Formless, nameles...the true master dwells within. Only you can free him. Come on, body! Many wellknown Kungfu masters will teach you form-form. Shaolin, Wudang, Taichi and many other linds of Kungfu. Anyone you like, just have a taste! Once chose, you will be a different person as before. Whoever you are, a painter, a butcher, a musician... To be YOU! Only $360 you can be YOU! Welcome to www.kungfuuniversity.com!
          China's traditional culturehttp://www.duolon.com
            it all really depends on your budget. je makes a really good piston but you may want to save money and go with say a srp piston. again budget is big here but you can put a price on a well built motor. so build to your needs and expectations. even if your just changing pistons its recomended to change out the bearings. stock bearings in a ls bottom are well known to spin at high rpm. keep in mind ls motor are not made to see a 8,000 rpm redline. a good set of acl bearing would help you out there and run you around $100. as far as cams go it depends on lift and duration. some camshafts recomend/require you to upgrade the valves, springs, and retainers. skunk2 and crower make some cams that require any upgrades so you may want to look into those.
            Manchester Honda since 1964
              its being built by me and im taking my time so it wont blow on me to fast im going with skunk2 pros Stage 2's cams valves, springs, and retainers.and im going to do the bottom end up 2. but only going to bring it to about 7500rpms. what pistons should i run the car will be all motor.
                je pistons is the way to go
                  If yore gonna be shifting at 7500 rpms, then the S2P2's are not what you want. The S2P2 acheive most of its increased HP from 7000-9000 rpms. I would suggest Pro 1's , or Tuner Stg. 2's.
                    also what rods should i use with this setup and i think im going to rev to 8000rpms some one told me use a the ls rods with a gsr crank?? idk tho
                      K-KILLER DAM LET ME FIND OUT i thought about je but never order them
                        like that dude said before if you on buget then for a buget build go eagl h-beam rods with a ls crank for a longer stroke
                          dont really have a buget just building this for a spair motor thats why i never order them i order parts for the motor im puting in my car..
                            I'm going to have and agree with both horny_for_hondaZeg888 and H23VTECLUDE. It all depends on whats is you're goals? How much Money? Budget? I'm doing the same thing Ls vtec but i have a b18b block with b16 head and trust me just do as much researching as possible. Deff go with Eagle H beam rods with the ls Crank If not i found a really good deal on ebay for Eagle H beam rods with Eagle Knifed edge Crank for ls for 599.99 which is not a bad price. Je makes awesome pistons and good power. Myself im heading with RS Machine Pistons with compression 11:6:1 but you can put all you want on the motor but at the end it all comes down to TUNING you have a good tune youre pretty much all set.
                            Dc <3'r
                            Viva Portugal
                            Honda-Tech S/n- Mikeb353
                            ClubIntegra S/n Mikeb353
                            Dc <3'r
