bearings?
  • bearings?
    rebuilding my motor.. not doing anything crazy just want it reliable... looking to see whats the best bearings out there for my crank/rods and can i use my stock pistons or should i get new ones..
    so..what i need to know
    1.whats bearings to get
    2.what kind of piston rings to get
    3. do you trust autozones waterpumps and oil pumps
    lmk going ro start buying sh!t
    autozone is goood stuff never had and problems with water pumps but bearings i would get honda or acl bearings
    mr.snuggles to you bitch
      i got acl race bearings on ebay they're the best you can buy
      i also got npr piston rings on there but they are made in japan and they make rings for oem manufacturers and are of the highest quality
      i never had a problem with aftermarket water pumps but if you want to be safe go to the dealer
        listen to this guy but i go with oem <acl bearings though. but either is good
        R.I.P Nick aka NHSwaps
          yea! and dont listen to the guy who actually built his own b-series on the stand ;)
            what kind of motor i it?
            Autozone-----waterpump.
            Oil Pump------HONDA ONLY!!! it cost a little more, but nothing beats OEM.
            Bearings---ACL, CLevite 77, Honda.
            Piston rings----NPR is ok, I like to use Total Seal, that's who ENDYN uses, or also HONDA stock.
              look at that every one autozone water pumps are good freakin bichos lol
                OEM Parts FTW!!! Use what has already been proven. If Stock motors go 200K plus, then why use anything diff. than they did?
                I am a firm believer in OEM EVERYTHING as far as Seals, Rings, Bearings, & Pumps.
                  well played sir
                    I would have to go with ACL thats what my car
                    :cool:
                      Iagree with kyle honda all the way. it's proven stuff all that acl crap and other brands for that go oem unless you are using aftermarket pistons and rods tha require certain fitments also if you go stock get the number off your crank and block and have honda get you the rite bearings and plasti gauge them for a good reliable build g/l on your project bro..
                      860 member #18
                      puerto roc #1
                      Cosa nostra
                      ASAPRadio.net
                        x2 very well explained
                        " Mr. Tough Guy "
                          go with oem!!!!
                          ive heard some bad stuff about acl..
                          !!!!!ThE GoOd DiE YoUnG!!!!!
                            ya ni666as must have a better autozone then we do out here cause i would never put on a water pump from autozone my .2 they sell a whole kit on ebay with pistons rods all the gaskets u need everything u need for an engine rebuild i just used it on a customers car and id use it again everything was made in japan everything looked good try and find it it came with type r pistons for 81mm bore well the compression atleast wityh stock pistons and rods ive used oem rings and king bearings ive used them on ALOT of motors and u can get the rod and main set for under 80 buks we use them on our low 8 sec race car so i think ill trust them on rice rockets
                              i use clevite bearings, total seal rings everything else in your list use OEM
